Hello, new member here. I am in the planning stage of installing a new wood stove with cook oven. I installed and owned a Vogelzang log wood stove previously but always got a down draft, a little smoke/soot into the house as the fire started to die/when it was windy/when the stove was not in use. I have since removed that stove and stove pipe to upgrade the stove and put the new one in a better location.
I have recently read that having the stove to close to the floor can promote a down draft like the one I describe. (I believe our 10' ceilings also promote the down draft because the neutral pressure zone inside the house is higher off the floor..I think?).
At the same time I understand that longer pipe lengths promote to much draft, and with 10' ceilings and a 12/12 roof I think I will need at least 17' of 5" stove pipe.
Where I am placing the new stove I will need to build a hearth and I have the option to raise it several inches off the floor. I can also buy extended legs for the stove which raise it another 3" off the floor.
My question is even if I can raise the bottom of the firebox off the floor by 6"-12" how can I know if we will still get a down draft back into the house as the fire dies? Is there some way to calculate at what height the firebox needs to be to avoid down draft?
