I removed my furnace from my basement a couple years ago. Now the basement gets very cold in the winter and I want to install a wood stove for supplemental heat. The furnace I removed was an Olsen 80k btu oil fired forced hot air. My question is it possible to reuse the existing furnace vent pipe for the wood stove? It was suggested that the existing pipe would not be compatible with the heat generated from a wood stove. Looking at the pipe it appears to be double walled stainless, but there are no markings, how can I tell what kind of pipe it is? I was looking at the Englander 30-NCH to install. The existing pipe runs from the basement up through my first and second floors and through the roof. If I had to replace the pipe I would probably consider other options for heat in the basement.
Other information that may or may not be relevant; my first and second floors are heated by combination of mini-split heat pumps and a harman p38 pellet stove. The basement is well insulated with 4" rigid foam insulation (inside) all around, although it does contain my heatpump hot water tank which adds to the cold temperatures. My location is in MA, so I am only looking for supplemental heat for the basement on the coldest of winter days (which the last two years has been all winter long...).
Any help or suggestions would be appreciated.
