Can someone identify which Fisher Stove I have?
Terooru
5
Ohio
Hello! Can someone please help me identify which Fisher stove I have. Here are some measurements and pictures. Thank you so much!
The first post of this thread will identify any Fisher Stove.
Reactions: Terooru
Hi. Thank you. I looked over this but am still having trouble. Don’t know if it’s a Grandma or Grandpa. Measurements fall in between what are posted. Not sure what version either.
Grandma Bear.
Notice how close the trees are at the door seam. Grandpa has a much larger space between trees.
The wider measurement s what I call a wide body some fabricators made. It has a wider front plate at the sides of the doors than a normal width Grandma. Also notice the door hinge plates are very straight. They should have an angle cut on the back and be angled outward as shown below;
Grandma barometric damper front.jpg Normal width 25 1/2 top plate, notice space from doors to angle iron corner.
Here's a wide one built like yours;
Grandma comparison.jpg Front plate shows between doors and angle iron corner.
Same doors and same size door opening.
Here's the difference showing the space between trees in the center of Grandpa doors;
Grandpa comparison.jpg Much larger door opening.
Reactions: Terooru
Grandma Bear.
View attachment 266517 Normal width 25 1/2 top plate, notice space from doors to angle iron corner.
View attachment 266516 Front plate shows between doors and angle iron corner.
View attachment 266518 Much larger door opening.
Thank you so much!! How much would you value ours at then? (Husband wants to sell, I want to keep).
Values and prices are all over the place. I'm in northern NY State, and I've never paid more than $300 for a Fisher stove. The refurbished Fisher stoves are worth more because I usually have $650+ in paint, new firebricks and other supplies needed to refurbish a stove.
