Can you post a picture of the stove?
That looks like a regency right? In the future if you are asking about a stove you should tell us what it is. But regardless if it is a regency you need to put a pair of vice grips on in the center of the tube and then hit them with a hammer driving thst tube to the left. It will pop right out. You should also read your m assnual that porcess is spelled out in there pretty well
That worked nicely!Lock onto the burn tube with some large vise grips, the give the vise grips a solid whack to the left with a hammer.
Making a block off plate. Cold air in winterOh yes, I see now the liner is attached via a stove adaptor, good. I'm just wondering tho, why are you taking liner off?? Most folks take the baffles out and either sweep down from the chimney into the stove body, but I like to clean from the bottom up. Just wondering...
That'll work. Just make sure it can't fall. The liner expands and contracts through the heating cycle and can cause the insulation to fall.Only issue is I can't get cement board in there. Will just have to be roxul.
