Use only dry seasoned firewood.T@LFarms said:I have a Harmon oakwood stove and wondered if there was a secret to keeping the vglass clean?
branchburner said:Wondering if this ties in with any of your other problems. What kind of wood do you burn, and how long cut/split/stacked? How long do you leave the bypass damper open before shutting it, and where do you set the air intake before and after shutting the damper?
T@LFarms said:I burn mostly ash and maple and I cut live trees around November then cut and split them and leave them stacked outside for year and a half and then put them in a shed under cover for use. I leave the bypass damper open until the fire is burning good 5 to 10 minutes roughly. The air intake is wide open until it gets going and then is shut down to about half way or less depending on the wood.
Backwoods Savage said:Welcome to the forum T@LFarms.
5-10 minutes seems a bit short. You might try shutting the draft down a little to a time and do it 2-3 times before settling on where you want the final draft setting. My guess is you are not giving it enough time to become a really good established fire. The wood should be charred before dialing down the draft. By burning it a bit hotter at the start this might solve the black glass.
For cleaning that black glass, use a damp newspaper and dip it into the ash. You don't need much ash; just dip it. Rub this lightly on the glass and it will remove the black really easy. If it is a bit streaked you can always use some windex and paper towel to finish the job.
Also, are you cleaning out the ashes daily? The reason I ask is because we have several new wood burners who do empty the ashes, sometimes before each load of wood. That is not only not needed but your fire will do better with some ashes in the stove. This time of year we clean our ashes no more than once per week and never take all the ashes out. We leave a couple inches of ash in at all times.
branchburner said:T@LFarms said:I burn mostly ash and maple and I cut live trees around November then cut and split them and leave them stacked outside for year and a half and then put them in a shed under cover for use. I leave the bypass damper open until the fire is burning good 5 to 10 minutes roughly. The air intake is wide open until it gets going and then is shut down to about half way or less depending on the wood.
Can't beat that for seasoning wood! I think five or ten minutes might be okay if you are reloading on a nice deep bed of hot coals, but not from a cold start. One thing I have noticed early in the fire is the secondary air, where it's injected at the back of the firebox, will burn up the coals in back very quickly. Then a partially-burned log can settle down and block the area. To fix this, or avoid it, I often lift up the log in back, and push coals underneath it from the front of the firebox.
I think the other fellows are onto something, too, with the idea of gradually stepping the air back. I usually go full open to 3/4 to 1/2 to 1/4, or something like that, over 10-15 minutes. But your glass should mostly be self-cleaning with hot burns. Is it very dirty all the time, or just sooty on occasion and then clean?
My other questions would be: do you ever see any visible smoke outside when the bypass is engaged, how many sq ft are you heating, and what is the flue setup that the stove is vented into?
firefighterjake said:1. Do not burn unseasoned wood . . . although if I had to guess from the sounds of it your wood is good.
2. Do not allow the wood to rest against the glass . . . although this is generally something that just happens once in a while.
3. Make sure your gaskets are good . . . although if this is a new stove this probably is not an issue.
4. Burn at the proper temps . . . you need to burn in the Goldilocks Zone -- not too hot and not too cold. Using a thermometer on the stove and/or flue will help.
5. Do not shut down the air too early . . . this is where a thermometer will help . . . it will let you know when you can start closing off the air to avoid suffocating the fire.
T@LFarms said:Backwoods Savage said:Welcome to the forum T@LFarms.
I am empting the ash pan daily. I will try your tip and let you know. Thanks
TC
T@LFarms said:branchburner said:T@LFarms said:I burn mostly ash and maple and I cut live trees around November then cut and split them and leave them stacked outside for year and a half and then put them in a shed under cover for use. I leave the bypass damper open until the fire is burning good 5 to 10 minutes roughly. The air intake is wide open until it gets going and then is shut down to about half way or less depending on the wood.
I am not sure about visible smoke, should you see it? My house is about 1300 sq ft and I have a stainless steel triple wall chimney that goes straight out of the stove and through the upstairs and out the roof, no bends what so ever about 18 ft.
TC
T@LFarms said:firefighterjake said:1. Do not burn unseasoned wood . . . although if I had to guess from the sounds of it your wood is good.
What type of thermometer should be used and where should it be located?
TC
firefighterjake said:T@LFarms said:Backwoods Savage said:Welcome to the forum T@LFarms.
TC
A very good tip . . . my own stove does pretty well with an inch or two in the firebox . . . helps preserve the coals.
TC
TC
Bigg_Redd said:T@LFarms said:I have a Harmon oakwood stove and wondered if there was a secret to keeping the vglass clean?
Keep your fires hotter
TC
