Hello,
This was installed 1 week ago, has worked perfectly. This morning the control panel is blank and flashing, any ideas what's wrong?
Un plug it, then plug it back in and see what happens.
Was the stove shut down by you, or did it shut down over night on it own?
I looked thru the troubleshooting guide and so far have not found anything about the panel flashing. Do you know why it shut down? Was it on a set time, or did it run out of pellets ?
Hopefully Rich2500 will see this. He is well versed at many of the unlisted troubleshooting ideas.
Try unplugging the ribbon cable from the back of the controller and reseating it.
Just received new controller and power supply switch replacement. New panel is still blinking and blank, so my question is, how do I remove the old switch? I'm the least mechanical person ever.Then I'm going to have say you got a bad controller and should give Ardisam a call.
Any luck? I hope you have heat again and the Serenity is working properly.
I have one and it is doing the same thing, sometimes it is completely blank. It still works just fine and since I know the keystrokes to on and off, it is not a big problem. I suspect that the issue is with the 12V to the LCD, so when I get a chance I will do a teardown of the controller display board.Hello,
