As promised, I took some pictures while cleaning my cat today. I learned some stuff about running my stove, too!
This guy has run for 2 seasons (~9000-10000 hours) in a Princess Insert providing the only heat for the house. (I do have an oil burner, but it only gets work when I'm out of town.)
It still works but it a lot less frisky than it used to be. Let's pull it out of there...
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199808-d5a26b03cb347c5f3f6e290a477fad80.jpg?hash=sqK8sb1FVy)
Oh, dear! The cat is plugged on the front side up top where you can't see it.... sneaky.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199809-cf07c4c0b52891fc3706068bd191be31.jpg?hash=R1XjMX9A9F)
The crud brushes off easily with a soft brush.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199810-7ea63e71ccaca395dc884d04235e9e78.jpg?hash=NE_BT5sK1l)
The front side of the cat has no cracks, despite some thermal abuse. The back side has lots of small cracks, but no bits falling off.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199811-2b01d507db4657ca65b463e44d8fe42c.jpg?hash=s9Cabp0O11)
And with the cat out, I learn something new about my stove. Not only do flue sweepings land on the ledge behind the cat, they also build up in the internal angle of the flue pipe. I have to start letting the stove go cold for sweepings so I can get up in there. Look at that! 2 years of loose crud sitting there blocking a significant chunk of my airway.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199812-5491d0b97983e52021e38c79063a3a73.jpg?hash=Ak7DgPm1za)
I do not have enough Wife Points to do the vinegar bath inside, and I've never used a rocket stove before, so voila... a double barrel cinder block cat boiler stove, here for one day only.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199813-104fe9d995ea80cf2a8aa1f4503720a2.jpg?hash=nMzl8N6M-5)
Cat grabber straps, and little feet to keep it off the bottom of the pot (you want liquid to circulate through the cells).
Disaster! I do not have a big enough pot to do this in. My big brewpot isn't wide enough, and my biggest baking pan is a bit too shallow.
A sensible man would stop here and get a suitable pot.... but not me!
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199814-de131e3dae27e6417de846c7032b1078.jpg?hash=zZ3lF-PpPN)
Does that look like a dumb idea? Come on, give me some credit.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199816-1ef6355bdbc910be720e59976f8817af.jpg?hash=aeWvapBxWJ)
Off we go. Soon I will discover that the fry basket full of tinfoil WAS a dumb idea, and I will lose a bunch of my vinegar and water directly into the rocket stove, making me, the fire, and everyone in breathing distance distinctly unhappy.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199818-736a34541d14df63a419d16f8d390614.jpg?hash=1OPQHnSlMl)
Back in business.
It gets boiled in a 50/50 mixture of distilled water and distilled vinegar for 30 minutes, then two 15 minute boils in clean distilled water.
Due to my very oversized second pot and my leaky dumbass first pot, I used about a gallon of vinegar and 4.5 gallons of distilled water total, including evaporation losses. If you had a pot that your cat fit in a little better, you could use less.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199819-976c2372bc6e8b5813adbb8d013abe5e.jpg?hash=vFLLgfqn8c)
Time for a walk while the cat cooks!
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199820-9ed3e3e396d615dc844f6587ded22aba.jpg?hash=1zdEo449OT)
Coming out of the last bath- looks pretty clean. Water is too low because I ran out of distilled water on the last bath. You want to keep ot above the cells so water can circulate through.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199822-f2914f8cd10be6d5996d25e8b2dc6fe3.jpg?hash=ePCsfa24ZV)
That cinder block stove is still cranking. Musta fed it too many twigs.
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199823-71574fcfddee2671fffe0a4fb107fe0f.jpg?hash=BYYLjGOBjZ)
After a half dozen tries at getting the cat in without folding the new gasket over, I said 'Heck with it, I am going to tape that thing down and the tape can just burn off later'. This works well. Later I look up how you're supposed to do it, and... you're supposed to tape it. Huzzah?
![[Hearth.com] Cat bath! [Hearth.com] Cat bath!](https://www.hearth.com/talk/data/attachments/199/199824-a37862cd94b23a034d487d1803c816fd.jpg?hash=oirvYbB5Ax)
That's it! I'll try to remember to come back and let y'all know how the old ceramic cat does (if it doesn't do well, I have a brand new steel one and a new gasket ready to go!)
Back in business.
