EDIT: Selkirk DSP (double wall painted pipe which I believe is galv under the paint).
I've got quite a problem with our cat stove. We're getting fumes from overtemp galvanized fairly regularly. Here's the predicament. Please let me know if (or should I say where) I'm doing something wrong. Here's how I run the stove.
Assume good 2-3 inch bed of HOT glowing coals and I'll be recharging the stove.
Plan A (no problems with the stove pipe but lots of smoke from the stack):
1. Open Cat bypass
2. Gather wood load (1 year + dry split oak and hickory) to be inserted into stove
3. Open stove door
4. Insert the wood half way or to the top depending on how much heat will be needed
5. Close the door
6. Close the bypass
Here's what happens after 5 minutes... LOTS of billowing white smoke from the stack for about 1-2 hours until the wood is black and partially covered by embers. The cat closes lets smoke build up in the fire box and restricts airflow enough that the load takes a while to burn. Then once burning well it tapers off after a few hours to no smoke and only coals after about 5 hours.
Plan B (and here is where the galvanized fume problem occurs):
Same as above except step 6 is modified:
6. LEAVE THE BYPASS OPEN for 30 minutes until the new load is burning well.
BIG problem... now the stove pipe crackles and gets so hot that if I touch the outside (of the double wall pipe) with a wetted finger it basically bounces the water off in a boil. If I don't close the bypass when this is happening it will get so strong with galvanized and paint fumes that we have to open the windows.
I know what this is... CREOSOTE burning in the pipe creating a small chimney fire. But how do I stop this? Plan A seems to generate the creosote, but Plan B also is a problem since it'll fire the stack so hot that it creates fumes.
1. Open Cat bypass
3. Open stove door
5. Close the door
6. Close the bypass
