Well, I just replaced the CC for the first time on our VC Intrepid II and I am impressed. Whenever we tried to get it to work in the past 10 yrs (stove came with the house), closing the flue to go into catalytic combustion just seemed to make the fire die down slowly. Also never noticed any difference in quantity or quality of smoke. Considering that I had cleaned the thing many times, and the cat was intact and looked good, I wondered whether the whole thing was a gimmick or just simply would never work in our setup for some reason.
After replacing the cat a few days ago, tonight I threw on a big dry hnk of white pine. Got her up to 550° or so and clamped down...and it got HOTTER instead of COOLER! It works, apparently!
EDIT [burning plastic questions removed]:
I'm curious about when to use the cat and when not to use the cat.
The old (circa 1987) manual says not to engage the cat until 450°F ... but then it says, "When thermometer readings drop below 350°F, it's time to adjust air control for a higher burn rate or to reload the stove."
Are they saying you can keep the cat engaged until it drops to 350°F? I'm confused about this 450°F versus 350°F issue...will I foul the cat with pine resin if the temp on a pine fire drops to 400°F before I disengage the cat?
Just trying to get used to the idea of a real, working catalyst. Thanks,
J
J
