Hi all,
So as I get a little more comfortable with my new wood stove (Hearthstone Green Mountain 60) I am also starting to operate it more with the bypass and air control closed to extend burn times. It seems to stay in the "catalyst active" range fairly well, but I still worry about the slower burn causing more creosote and clogging up the chimney.
Would it be wrong to assume that if significant creosote was making its way up the chimney that the cats would clog first? I've cleaned out the cats once this season and they were fairly clean, which makes me think that the chimney wouldn't be building up too much creosote either. I'm sure the temperature of the cats is hotter than the stove pipe, so perhaps my assumption would be wrong based on that alone since the higher temperature of the cats might be hot enough to burn off creosote that wouldn't burn off in the chimney.
