Ok this thread was added to alot since last i checked I'll try to get everything answered.
@maple1 my protection is doing it's job well anything over 145° the bypass side is completely shut. The bypass tube goes "cold" while burning. And i have tried many different circ speed combos. It seemed the same speed on each yielded best results. Currently I've switched boiler back to speed 2 and storage is on speed 3.
@hondaracer2oo4 I have set up an account on flat plate. That's where i sized my current HX. but not having a good idea of my flows and boiler output i was guessing, at best, at many of the numbers. The HX i settled on is the exact one from that eBay ad. It's a 20 plate at those deminions.
@Bob Rohr There's not really a good way to put coils in my boiler. Given the internal construction and internal flue HX there's a bunch of things in the way and doesn't leave alot of easy working room in there.
@Marshy my biggest concern with a much larger HX is 1) cost and 2) if boiler return temps drop below 145 then the mixing valve will be bypassing pretty often. Which i know is it's job, but if i can send 150° water back to the boiler I'd be alot happier.
