Chain saw concern
jotul8e2
595
Ozarks
I needed to use the old Stihl 362 today for the first time in about five months. I put in a tank of gas mix and one of bar oil, set the choke and pulled the cord until it "popped". A few more pulls and the saw fired up, ran smoothly, and even idled. The chain was sharp, cut well while throwing out large chips. After cutting up a score or so of logs I shut it down and when I pulled the starter cord a few minutes later it fired right up and idled once again.
Frankly, this is the first time this sort of thing has happened to me. I am wondering if I should get out the little screwdriver and fiddle with the adjustment screws. Any ideas or suggestions?
*** For those deaf to irony, the above is intended as an example. It is similar to, but not exactly the same as humor.***
Sounds like a guy I worked with. We develop something that works. Run with it? No way. Let’s try every other off the wall idea to make sure it doesn’t work first.
Reactions: SidecarFlip
My philosophy. If it works don't screw with it.
Reactions: D8Chumley
If I had a dollar for every time I tried to improve something ...
Reactions: Sean McGillicuddy
" If it ain't broke don't fix it "
Isn't there a Marx Brothers scene where Chico is a barber trimming a guy's mustache? He's trying to make it even and keeps having to take a little more off the other side until he removes the mustache.
"Justa one-a more snoop!" :)
