Challenge to find inserts < 16" deep?
Oct 4, 2018
100
Connecticut, USA
We're considering replacing a gas fireplace with a wood insert. The depth is only 16" but the height is 29". I've only looked at Blaze King, Pacific Energy, and Regency, but I haven't found any inserts that will fit. I think Pacific Energy has one that will fit depth-wise, but the surround is 2" too short.
I was hoping to put in a wood insert without spending too much money. Is knocking out the back wall of the firebox even a possibility? I guess that's a case-by-case problem I'd need to talk to a dealer about.
Surrounds can be extended by attaching a strip of metal. Is it short on the top or sides?
I don't know your fireplace size, but some inserts are adjustable. The Lopi Freedom is large and can go in as shallow as 13.5".
When you say replace your gas fireplace what type is the fireplace?
Masonry I think. It's a brick hearth and feels rock solid. But half-way up it transitions to drywall and the drywall sounds completely hollow like it is enclosing the vent pipe.
Post some pics. An insert may not even be an option
