Champion 34 ton vs 37 ton log splitter
dwol
15
I just bought a champion 34 ton log splitter only to find out that the new model is 37 ton. Does anyone know what has changed? I reviewed the specs and everything looks identical. The engine is the same, the cylinder is the same (bore and stroke), even the weight is the same. Did they really just change the number on the side from 34 to 37? It leads me to believe that the manufactures can put any claim they want on tonnage. Is there someone out there that verifies these?
Kind regards,
Dave
brenndatomu
8,117
NE Ohio
It's pretty well known that they kinda make up the tonnage numbers on many splitters out there...especially the "non pro level" models that most of us have.
Chances are that if you actually put a gauge on it, the pressure that they claim doesn't actually occur...then if you plug all the info into one of the "log splitter build calculators" you can find the real tonnage that it is making.
Reactions: dwol
dwol
15
Thanks brenndatomu,
I wouldn't be surprised to see this same log splitter rebranded as a 40 ton unit in 3 years...(they are only 3 tons away at this point)
ericm979
400
California
There's no one who verifies these self-ratings. 4.5" at 3600 psi is 27 tons. Thats what my splitter does and it's very rare to stall it even on Eucalyptus.
JRHAWK9
1,998
Wisconsin Dells, WI
This is what I was expecting with my 40 ton. I was absolutely taken by surprise when it was very close to rated when I put a gauge on mine. Only reason I don't know for sure is I bought a 3,000 max psi gauge, thinking it was going to be plenty. I then discovered as soon as the pump hit the second stage the needle on the gauge flew past the 3,000psi mark and I let off immediately. I believe 3,880 psi (5.125") is right where it would be making 40ton. I dialed it back to a little over 3,000 psi.
To the OP, I would call the manufacture and talk to their technical support staff and ask what's the deal. I'd like to hear what they have to say and to see them squirm trying to make something up. LOL
JRHAWK9
1,998
Wisconsin Dells, WI
4.5" @ 3600 is 28.6 ton according to my calcs.
=(((4.5*4.5*3.14)/4)*3600)/2000 = 28.6
JRHAWK9
1,998
Wisconsin Dells, WI
dwol
15
It looks like your calculator does not have "cylinder rod diameter" and bore is "5 inches" not "4.5 inches". I used the calculator below and it comes to just over 35 ton, or 70,686 lbs.
-please verify if I am not correct.
JRHAWK9
1,998
Wisconsin Dells, WI
When the ram is being extended (like it is when splitting), you don't have to subtract the area of the rod, as the fluid behind the piston is the full ram diameter. To compute the splitting force tonnage applied to the wood, only the ram diameter and pressure is needed.
dwol
15
Thanks JRHAWK9,
That makes sense. I am guessing that is why there are two pressures on the calculator? One for push (no rod factor) and one for pull?
Reactions: JRHAWK9
JRHAWK9
1,998
Wisconsin Dells, WI
Thanks JRHAWK9,
That makes sense. I am guessing that is why there are two pressures on the calculator? One for push (no rod factor) and one for pull?View attachment 309436
yep!
So it's a 35 ton splitter -IF- running at 3600psi max.
FWIW, mine hardly ever goes over 500psi when splitting oak. I have a 4 way wedge this year, so we'll see what difference in pressure I see when in use.
vbu
Burning Hunk
Mar 3, 2019
227
MS
yep!
The 4 way wedge will give your splitter a workout, that's for sure. I ended up taking mine off after several years. Very frequently I found the 4 way wedge to be cutting instead of splitting the wood, often making a mess of things. I took it off and I feel like I'm splitting faster now but that could just be my thoughts
JRHAWK9
1,998
Wisconsin Dells, WI
I split a lot of straight grained oak, so I don't expect too much of an issue. I didn't like a 4 way before whe I tried it on my on my other splitter because I liked to micro-manage the size of my splits. ;lol I've since decided I actually like to have a mixture of small/large splits vs all larger ones, so I'm going to give the 4 way another crack.
vbu
Burning Hunk
Mar 3, 2019
227
MS
gotcha. Yes it works well on straight grained stuff, but when you run into knotty stuff you'll make a big mess real quick. I may end up putting mind back on too one day
JRHAWK9
1,998
Wisconsin Dells, WI
Here's a good example of what I am splitting.
Isaac Carlson
1,131
NW Wisconsin
Mine is set to 17-18 tons. Not usually more than 800 psi, even with the 4 way, crotches will take it to 1500, but rarely more. It's a 4" cylinder and I made the 4 way myself.
