Changed the oil/filter on the wood hauler (riding mower) and......
Shari
2,341
Wisconsin
had a little problem getting the filter off:
[Hearth.com] Changed the oil/filter on the wood hauler (riding mower) and......
At least the filter held up when you impaled it with the screwdriver. I've had the skin come off the filter before...then they are real not fun to get off.
The worst was the first oil change on my truck. I think they have a gorilla torquing them down at the factory to about a billion lb/ft.
Here's what I've got for the difficult ones. Hasn't let me down yet. Steel Band type work very well too.
  • [Hearth.com] Changed the oil/filter on the wood hauler (riding mower) and......
yes Dodge has the same gorilla installing thier oil filters.
first tool he is issued is a 6 foot cheater bar and Wheaties
It's VERY common to find the factory oil filter has been installed by a 900lb gorilla with a 3 ft breaker bar. >:-( Applies to all makes/models.
I smeared a bit of oil on the gasket before installing the new filter - hopefully I won't have this same problem the next time! :)
actually after looking into this
the car companies install new filters dry
so they glue thenselves in place
HehHeh . . . saw the picture and immediately started laughing when I read the "had a little problem getting the filter off" . . . thanks for the laugh Shari.
I am sure you showed more common sense putting it on than the last person.
PapaDave said:
Looking at that filter (is it really?) makes me never want to get in a fight with you. :lol:
And this made me laugh even harder! :) :) :)
This was a Ford. I said a lot of bad words that day (way more than usual), but it finally gave up and loosened. If I remember correctly I did have to use a cheater bar...not quite six feet...so does that make me stronger than a gorilla LOL?
Well... there was this one time, years ago - "It was a dark and stormy night......" (fill in the blanks yourself, but but keep it clean as I was actually defending my younger sister). In short, the guy's glasses needed repair. :)
First time I changed the filter on my new 1988 S-10 Blazer I removed half the skin from my hands trying to get a band wrench down in the tight space and then find room to clear the handle to turn it. Ended up doing the drive the screwdriver through it thing to get it off.
The next time I was in the dealership for warranty work a mechanic pulled one just like it up in front of the window of the waiting room, reached in over the left front tire and spun the filter out and replaced it. Two minutes max. >:-(
That's exactly what I did to the Tacoma first filter.
Not only did a Sumo wrestler put it on but whoever designed the position was a service misanthrope.
For $13.95 (lifetime deal) I don't mind someone else bashing their knuckles at all.
Same thing on my lawnmower during the first oil change. I didn't have room to poke through it so it was a bang it from an angle and pray it broke loose kinda thing.
I'll bet most of us have cursed when getting an oil filter off.
Yep new 1975 Ford van with a 351, three hours later I was still cursing.
Hey, oldspark - your comment makes me feel good as I almost had to call in reinforcements (a 78 yr. old friend).
Dang kids! You feed 'em, raise 'em up, they marry, move away and you don't have the help when you need it. :)
I wrench for a living and often get frustrated until I get the trick. I was dreading changing plugs in my van till one day I noticed they were all easily excessable and straight on shot through the wheel well. Ended up being the easiest I had ever done. Man built it man can service it!
How do you like working on VW?
I know the answer... it contains many four letter words.
I don't work on little wheels, I work on wings or as a hobby big wheels (tractors).
My 1991 S-10 had the remote kit too. You know how long it takes a 16 year old kid to find a remote oil filter. Hint, longer than two minutes. :lol: Didn't take as long to find the door in the skidplate on my 1997 S-10, after I cleared off the mud that covered the "Remove for Oil Filter" stamped on it. :red:
+1 on that. My own equipment excluded, I avoid working on things with license plates. Not for the lack of ability but I'm just not set up to turn a car around in a reasonable amount of time. People are VERY impatient when it comes to their cars.
