Cherry Tuesday
thewoodlands
17,980
In The Woods
I had a cherry down in the same area that I've been working so I went back in an bucked it up, part of it I'll pull out of the tree with the winch another day.
zap
  • [Hearth.com] Cherry Tuesday
cherry is always a favorite, a quick dry, and a great smell.
Wood Splitter, you can like them both, totally different. Take the Locust for the heat, take the cherry for the smell and medium burn. They both season quick. The Locust doesn't smell very good, but worth it.
Zap, is it not like 100+ in the shade there? You are doing so much work that I'm sweating just thinking about it. I think I'll stay right here in my recliner for another week or two.....
85 and muggy, I take my time plus rest if I'm tired.
zap
Danno77 I thought I was cutting this cherry but the more I look at it I think there is another cherry in that area. It's not the same tree I cut tonight, this picture is from the same area.
zap
That one surely is a nice looking log! Have at it Zap.
Once I find it I'll get it done, it should be in the area I cut the other cherry.
zap
Nice to get it off the ground and mill that one later.
I'll mill it Sunday for the wood stove! :vampire:
zap
zap
When you get your mill set up I will post that cherry pic again! lol
smokinjay said:
zap
I have some bigger cherry in mind, smokin on the 660 stihl would I need the auxiliary oiler on the mill?
zap
zapny said:
smokinjay said:
zap
zap
Without question it will run much cooler better proformace, saw will last longer.
What thickness can you mill with your setup.
zap
zap
from a 1/4 inch to 12inch to 32in wide. Its called a 36inch mill doesn't make much sense.
smokinjay said:
zap
from a 1/4 inch to 6 inchs
Spoke with a company yesterday and they recommended the MK-3, said I could buy the auxiliary oiler for that setup. I your setup for two power heads?
zap
zapny said:
smokinjay said:
zap
zap
no I just went with the basic 36in. alaskan mill and also the mini mill 79.00 for the first cut aux-oiler 35.00. with chains 350.00 bucks its all you need. The complete kits you pay for that double header bar.....Really not needed and the 2 saw would need to be the same saw set to the same rpm's just to much to go wrong. With a 660 I would go with a 30in rail if you ever get one to big for it you just run boards off the sides until it fits.
