I have a gas grill for the quick grill meal and two Weber kettles for charcoal and smoking. Sell me on a pellet grill / smoker, GO!
We had this one,
(broken link removed to http://www.outdoorpros.com/Prod/Char-Broil-06701289-H2O-Charcoal-Smoker/67881/Cat/1558)
It did the job but we had to keep adding charcoal and it seamed to never get hot enough even with good charcoal.
I will check out your link as we miss smoking.
I use my kettles for smoking, which I have figured out running them, sometimes it's a challenge to keep the heat right.The units I've looked at look good. Most hold 20 lbs. of pellets which will allow you to cook over night at a set temp without haveing to tend to it as it will hold the set temp. The down side is the cost. How often do you smoke ? I have a kettle grill that I enjoy. As I can use it as a smoker or a grill.When I'm smokeing it might take a little more attention in maintaining tne temp. But I also only smoke once a month or so.
Check Louisiana-grills.com They have everything from cold smokers to grills. My CS-680 can be used at any temperature from a hot smoke (around 220F) to grilling (650F). Mine is an older model so it doesn't have the flame broiling option.They aren't grills. They are smokers.
Made in Ramsey, MNCheck Louisiana-grills.com They have everything from cold smokers to grills. My CS-680 can be used at any temperature from a hot smoke (around 220F) to grilling (650F). Mine is an older model so it doesn't have the flame broiling option.
Check out the Kamado (egg-shaped) cookers. I have a cheap Char Grill Akorn and I love it. You can smoke, grill and bake in it. Mine is not a high end $1000 ceramic one, but for $250 it does a good job. Mine uses charcoal but they are making pellet fueled ones but they are even more expensive then the traditional charcoal ones... almost $2000.
http://blackolivegrill.com/products/pellet-grill-l/
Is your Char-Griller ceramic?
