For 21 years I used to have a Regency I3100 wood insert and never had any problems burning 6-8 hardwood cords every winter. Once during a summer chimney clean up they suggested my chimney cap (as per attached pic.) was too small and offered a larger SS one which I purchased. However during my first use in the winter I noticed that the draft was excessive and the first chance I had I re installed the old cap which has always gave me a good draft control. However I learned that increasing the cap size it provides more draft.
Last Fall I had to replace my I3100 due to cracks with a new Regency I2450 and noticed I almost have no draft control regardless how far I opened the draft lever. Searching on this forum I learned that this insert has a baffle at the top of the firebox which is a common problem on these inserts and perhaps needs adjustment to increase the draft.
I have been unable to access this baffle inside the firebox, kind of too difficult for me, and I was thinking perhaps it will be easier to replace my chimney cap with a larger cap like I did with my old insert. What is your opinion?
For further info, the chimney cap is about 35 feet from the ground and there are no other buildings/trees around my chimney.
Thanks
![[Hearth.com] Chimney Cap Size [Hearth.com] Chimney Cap Size](https://www.hearth.com/talk/data/attachments/338/338251-2738c6cad7ce6478e87545b6f2cb5152.jpg?hash=euOKWD3K47)
Thanks
![[Hearth.com] Chimney Cap Size [Hearth.com] Chimney Cap Size](https://www.hearth.com/talk/data/attachments/338/338260-11a27baf3de07aacbac44835197fb6bf.jpg?hash=_PLHXRKOzq)
![[Hearth.com] Chimney Cap Size [Hearth.com] Chimney Cap Size](https://www.hearth.com/talk/data/attachments/338/338267-f02d82d8346755d1c83aebd54325e289.jpg?hash=FvOij7Apxu)
