The fire is generally got flames, unless I've gone to bed.
What does this mean? What happens when you go to bed?
The fire pretty much turns to embers once I stop throwing logs on.
I hope that fireman does not want to justify his job by selling unseasoned wood.
And I was burning the wood pretty much right after splitting it - no good?
How does one measure moisture content, after re-splitting? And I was burning the wood pretty much right after splitting it - no good? The chimney is 6 ft. to the ceiling, 8 ft. in the attic, and probably three or four feet from roof up...How can I tell if it's single or double-walled?
If you don't have a moisture meter, try resplitting a thick split in half. Then take the freshly split face of the wood and press it up against your cheek. Does it feel dry or cold and damp? Bang the two halves together. Do they ring with a musical note or do they go thud? If it feels damp and goes thud, the wood is still wet inside.
My first guess was also moisture content. If we rule that out what. Else could it be? All fires need heat, fuel and oxygen. You are getting all 3 at the right amounts.I have had two chimney fires in the last two years with my Atlanta Model 26 wood stove. Am using aged, dried hard wood and no sappy pine, get it cleaned annually, etc. The stove pipe goes through about 10 feet of uninsulated (i.e. freezing cold) attic, which I'm thinking could be a contributing factor. Am looking for helpful advice on how to avoid future chimney fires! Thanks.
Seems moisture content in the wood is in question here. I plan to pick up a moisture meter soon given the nature of this thread and that I am new to an old 30's vintage wood stove! Others have posted that Lowe's sells a pretty tried and true meter for under 30 bucks. Seems like cheap insurance in light of regular flue fires.
Can someone reiterate the ideal moisture content/percentage as well as an acceptable range for burning?
The logs I just re-split feel pretty dry = cold, but dry. When I strike them together it's more of a ring than a thud, so I think the wood is fairly well seasoned. It is not, however, cracking on the ends which I know is a sign of very well aged wood...
So, I guess I have to:
1) Have the chimney cleaned twice this year.
2) Find some even drier/older wood.
Question: is it possible to insulate the pipe in the cold attic? Does anyone think that could be contributing to the frequent chimney fires?
Thanks all for your great replies!
I have no clue about temps.
Go to lowes, pick up a moisture meter, go home split your wood the way you usually do it, test the wood with your new meter and post your results here ASAP, also any pictures of your wood split and whole would help us out.The fire pretty much turns to embers once I stop throwing logs on.
I just picked up a burn indicator at lowes for 11 bucks. Mount on the flue 18" above the woodstove
- I think it drafts pretty well, although I have to keep the flue wide open or it smokes out a bit.My first guess was also moisture content. If we rule that out what. Else could it be? All fires need heat, fuel and oxygen. You are getting all 3 at the right amounts.
Does the chimney go straight up through the roof or does it have elbows?
-Straight up- no elbows.
Is the chimney only used by this stove?
- Yes
How do you light the fire? Do you use cardboard or fire starters, pine cones?
- Usually very dried kindling from woods, sometimes use a fatwood stick.
Are you the only one loading and maintaining the stove? I ask this because my wife use to use our stove similar to an incinerator?
- Just little ol' me. And I only burn wood, newspaper, kindling.
Do you burn a lot of smaller scrap wood?
- Sometimes get scrap wood from carpenter friends, but mostly I burn logs, and kindling from the woods.
Animal nest in the chimney? What time of season does the fire occur? Beginning , middle , end.
- No animal nest. The first chimney fire was mid-Feb, then again mid-Jan. the following year.
How well does you stove draft?
I am attaching some pics to help describe the situation here:
I will purchase a burn indicator today. Thanks.I just picked up a burn indicator at lowes for 11 bucks. Mount on the flue 18" above the woodstove
I will also buy one of these moisture meters today. Thanks!Go to lowes, pick up a moisture meter, go home split your wood the way you usually do it, test the wood with your new meter and post your results here ASAP, also any pictures of your wood split and whole would help us out.
And a few more pics of the wood, and the anti-creosote stuff I use on every fire:
I posted a pic of the pipe inside, attic and roof. It doesn't look/sound insulated to me, but I'm new to all this. I will buy wood earlier and stack it for the spring/summer, but for now, I've got the wood I've got! Will get more if it turns out to be more than 20% moisture.... Thanks for the stacking ideas!To be sure I would get a moisture meter. Look in your local hardware store or try this here for less than $20 with shipping: http://www.harborfreight.com/digital-mini-moisture-meter-67143.html
If your chimney is straight up I would give this here a try: http://gardusinc.com/sooteater.html It does a good job, takes about 30 min from start to finish (including clean-up) and does not cost $100 every time. I would run it once a month in your situation.
That, and get some more cords of green wood that you can stack outside to dry for next year. Only then can you be sure that your wood is seasoned. Here is an "ideal" setup:
http://www.instructables.com/id/No-tools-firewood-rack/
But you can also just stack the wood on pallets if you don't want to spend any money. It looks surely like more work but you should notice that you will need less wood. Btw. Your stove is a pretty old and inefficient one. If you are committed to woodburning I would think of replacing it with an EPA-approved one. You will cut your wood consumption in half.
You can insulate it but maybe we should check what kind of pipe you have and if it would be advisable to replace it. Can you get up in the attic and get some pictures? Maybe also one of the setup on your roof?
See pics I just posted. Thanks!What kind of chimney do you have?
Yes it is possible to insulate the pipe in the cold attic. Just do a search on "Chimney liner insulation". The easiest type of insulation is a blanket that wraps around the pipe.
Yes It should help reduce creosote accumulations by improving draft and keeping the flue warmer so that the gases don't condense. A cold flue will require more cleaning to prevent chimney fires.
But the best thing you can do is burn dry wood!
And have you used the sooteater? Do you think it really works?
