Chimney Liner Advice
Midwestburn
9
Minnesota
Hey all-
Thanks to your help, I've landed on a Kuma Alpine LE insert.
The problem I'm facing now is what to use as a liner.
Going with an insulated liner seems like the best option, however in my inspection of the chimney today I'm doubtful one would fit.
The dimensions of the clay can be seen in the attached pics. The liner goes 12' straight down, has one slightly offset tile, and then another offset tile before it ends up in the brickwork above the existing fireplace. Total length 22'. The clay has been resurfaced/relined with Cecure heat shield.
I'm pretty sure I could get a 6" uninsulated liner down. I've ran many such liners for gas appliances. I spoke with 4 different reputable dealers, and a certified chimney sweep company that we subcontract sometimes. All of them quoted for an uninsulated liner, and said insulation is beneficial but not necessary.
Given that it's the safest option, I'd like to do an insulated liner, but it may not be an option with fit.
Is there a product that would work with this application?
  • [Hearth.com] Chimney Liner Advice
The liner would need to be ovalized to fit if insulated. That's fairly standard practice.
Code dictated whether an insulated liner is needed or not. The requirement is based on the chimney's clearance from combustibles, including wood framing. If it's an interior chimney then it need 2" clearance all the way up. If exterior, then 1".
It's exterior, and house was built in the 60's so I doubt it has 1" clearance.
Would a 6" pre-insulated liner, like the one from Rockford, theoretically be able to be field ovalized to fit?
It's worth checking to see. The 1" doesn't include trim.
Duravent has insulated rigid oval liner that I used at our old house. It might fit depending on how big the offset is in the clay flue.
The wood framing below the rafters is damn near attached to the chimney so I'm guessing this wouldn't meet the 1" clearance. It looks like the portion of the chimney in the garage was wrapped in cinderblock.
