I know if it was me a Class A pipe even painted to match the house color sticking out the side of my historic house running all the way up to the roof would be out of the question.
Heather needs to read their documentation. Try another tech at M&G. Their rigid liner is 0 clearance as is Duraliner flex, with an insulation sleeve. If you need flex, install insulation at the points where there is exposed wood. It will get this job done safely, legally and will keep the costs affordable. (broken link removed to http://www.duravent.com/Product.aspx?hProduct=6)
Just got the price quote for the liner inside a liner proposal outlined above. $9000
Thanks for posting that, begreen. Looks like I need to make another call to Duraliner. Not sure why I got bad info on my first call.
Hmm, that is discouraging. Considering that you have good access on the lower part, what if metal heat shields with 1" spacing off the wood were installed? And is that an option by opening one side of the upper chimney where there is also exposed wood?
I went the same route as you contacting Supaflu and they gave me a number to a local sweep/chimney guy who came out and gave me a bid. I think I had it done last April before it got too busy. I dont know if it will work for your situation with all that exposed wood but I'd keep trying to contact them.
If it can't be lined safely maybe you can cap it off, drill through the back of the fireplace to the outside and run class A up the side of the house and build a chase around it if you don't like the look of the pipe?
Just stretching here, but how about the Duratech double wall rigid in the area where the wood is, an insulated flex extending off that the remainder of both ways? I have the same double wall rigid in my sytem, with 5' of flex at the bottom to the insert.Spoke with Dale in tech support at Duravent. His statement: "there is no way to line this chimney." Basically, any chimney "liner" requires a properly constructed chimney, with no internal combustables. They are only rated with respect to combustables touching the outside of the chimney, not having them inside the flue. While he did not say my installer's proposal was unsafe, he did say it was not legal. He said the same stands for (their) poured chimney product.
He said the only hope of lining a chimney with internal combustables would be to use a stand-alone chimney product, such as Duravent Duratech double-wall chimney. This only requires 2" clearance to combustables. Their 6" product has an 8" OD, and therefore requires a minimum 12" masonry flue. Because it is completely rigid that 12" minimum chimney must also be straight. Unfortunately, we know that is not the case with mine, which jogs in the area where the combustables exist.
Things are not looking good!
I did not see any wood.
Wow, gotta love that. I would insist that they take the 4" liner out of the chimney for free and run a camera down. It is a shame there are so many bad chimney sweeping tech's (notice I didn't say companies) out there these days. I would tell them to send a new tech WITH his list of NCSG and CSIA certifications over ASAP.
