Chimney question
pjohnson
Burning Hunk
145
ive got an 8 inch metalbestoes chimney that clears the peak of my roof by maybe 4 or 5 feet. When the wind was right the smoke would follow the roof down and come in a window. I went to buy another section of pipe and it had to be ordered and was around 400 dollars. He suggested to try a regular piece of stove pipe and see if it worked before spending money on the right pipe. I did and it works great no more smoke smell. So my question is what’s the down side to leaving the section of stove pipe in there.
Because it's connector pipe, not insulated Class A chimney, it will cool the flue gasses causing even more creosote deposits than would be there with Class A.
Another problem may be that your insurance would refuse to pay in case of a fire, since the chimney is not installed according to the stove and chimney manufacturers' instructions.
$400 sounds kinda steep for adding 4', but maybe not once you add up the liner-to-Class A adapter, 8", chimney and bracing you might need, plus labor. Did he give you an itemized estimate? Could you do it yourself?
Thanks for reply kinda of my thoughts with the creosote and cooling. I’ll be installing a new stove this weekend so I’ll try removing it. If not I’ll look online and order it. I can install it my self probably have to brace it if I go any higher. This 8 inch pipe is getting hard to find in any stores.
