I'm running a homemade OWB that's about 10 feet from my garage in its own shed. the chimney is pretty much at that 10 feet mark from the garage. and is about 10 feet off the ground at the top. well when I light the boiler for a batch burn it takes about 30-45 minutes to start burning more clean and getting less smoke out of the chimney.
My problem is while I'm waiting for the smoke to clear up it gets driven back down to the ground and drifts across the yard into the neighbors property. so it's my understanding that "smoke" is naturally heavy and falls to the ground anyway but will adding 6 more feet of chimney help my situation, or will the smoke still hit the ground and drift to my neighbors?
So my garage is in red. boiler shed blue, chimney black.
Peak of the garage is about 15 feet high. the chimney is about 10 from the ground now. if you draw a line to the garage roof at 10 feet is about 12 feet from the opening of the chimney. so will 6 more feet help me get the problem smoke up and out of the yards?
Hopefully all this makes sense.
