How high does my chimney need to be to be effective? Here's the background:
I just bought an insert, a QuadraFire 2100i, that I'm installing into a prefab metal fireplace in my upstairs. The existing chimney is only about 13' from the top of the stove to the cap. Is that high enough?
The existing chimney is 9" or so (hard to measure from the bottom, need to climb up on the roof), and is clear of the peak of the roof (the 10'-2' rule), but I'm worried about the total height. I live at about 8500ft in the CO mountains, and I've heard you need a longer chimney the higher up you go, but I can't find any recommendations on how high I should make it.
If I do need to extend the chimney, how would I go about that? I was planning on running a flexible stainless liner down, since the flue of my stove is 6". Is there an easy way to extend off of the liner, or is it going to be easier to run rigid pipe down and extend off of that? How do I secure the new chimney when it exits the old? It gets windy up there, I'd be nervous to have something sticking up high without some bracing.
Thanks for the advice.
