								It's definitely not rust from the roof. So, I'm guessing creosote, but weird that it's only on one side.Is that rust or creosote staining? Hard to tell with the roof being wet, you must have got the same rain we did today.
I don't know, but likely at least 15 years old since that's when his house was built. Could it be the difference between a catalytic (ours) and non-cat stove (probably his)?The neighbor may be running with a hotter flue and/or drier firewood. What stove is the neighbor running?
We cleaned it with a sooteater last January, after a lifetime burn of maybe 2 cords. We got about a cup of fine powder from that cleaning. We've burnt about 1.5 cords since then. Will shut it down next week for another cleaning and inspect the chimney. A leak in a chimney joint would explain why it's all on one side of the chimney.When was the last time time you cleaned the chimney? Probably creosote, metal roofs do not rust anymore with Galvalume being used now. A leak in a joint probably.
Yep, it's been drizzling all day here on the north shore of Lesser Slave Lake. We're not far from you!Is that rust or creosote staining? Hard to tell with the roof being wet, you must have got the same rain we did today.
They absolutely do still rustWhen was the last time time you cleaned the chimney? Probably creosote, metal roofs do not rust anymore with Galvalume being used now. A leak in a joint probably.
We're in Marten Beach. That fire in Slave Lake was tragic, we had lots of homeless friends.That's pretty close. Which end on the north side, Hilliard's Bay or Marten Beach area? I spent a couple years in the town of Slave Lake as a kid, dad worked at the OSB mill until Weyerhauser sold it to Tolko, then we moved back to GP. The house (and whole neighborhood) we lived in was lost in the fire.
We're going to inspect and clean the chimney next week. Based on our last cleaning (Jan 2021), we expect it to be pretty clean, but definitely worth a look. I can live with the stain, but not with creosote build up. A neighbour here with a BK had a chimney fire last week. Pretty scary with the fire dept 30 minutes away! They almost lost their house. It's made us extra cautious.Beautiful area up there. We still knew a few families living there at the time as well that we're left homeless, I'm still in disbelief to this day.
Back to the topic at hand though, how does the inside of the chimney look? Is there a bunch of creosote build up inside it as well? The cap definitely looks pretty black, but if I'm not mistaken that looks like an ICC Excel cap, my parents have the same and it gets some buildup over the winter as well with a traditional non-cat stove, the wind just cools it off enough to allow buildup. I wonder if the deluxe raincap with the windshield would help or hinder the problem? Otherwise if the chimney itself is clean it shouldn't be too much of an issue, just clean it off when the buildup accumulates too much, you'll probably just have to live with the stain running down the roof.
