Circular saw upgrade
Dang.
Where's the chain brake that engages upon kickback...?
Kickback was the first thing I thought of. The chain brake never crossed my mind.
Good catch!
It's a scary piece.
Stumpy Nubs has a few videos on YouTube about similar implements.
Why would you get kickback if you use it as intended? You won't be jabbing the end into the wood, and with the direction of rotation it will just pull the saw down onto the saws deck if it grabs.
Really I’d rather the really big circ saws and cut both sides. I thought about one when cutting beams out of a 4” slab. My guide attachment for the chainsaw didn’t work very well.
I've seen circular saws jump out of people's hands when they squeezed the piece in the wrong way.
Folks using circular saws are often not aware of kickback possibilities; not used to thinking about it as we are.
Any misalignment can result in kickback with this thing.
Those have been out for years...
  • Wow
Reactions: stoveliker
The physics involved are different though. A circular saw typically pinches at the bottom, where the blade is travelling away from the operator, kicking the entire saw back at the operator.
This is different, mostly, a pinch on the cutting side pulls the saw down into the wood. Only if you managed to pinch the backside would it kick back up.
You are right of course.
However, my circular saw has a cover that slams back when the blade gets out of the wood.
This thing will have a rotating chain exposed.I prefer it not to kick back up at me or flying over the place like that.
Anyway to each his own. This thing won't be mine...
I'm asked about these cheep off brand chain saws or something like this. Where are you getting the replacement chain? Just last week someone I know purchased a unknown to me saw and did a day of cutting. He explained it cut ok for a few hours, and then as you could guess it was not so good. My guess is the chains on these things are cheep untempered steel.
If it’s not a weird size, a local shop could probably make one from a roll of bulk.
I bet your right about a shop that could make a chain from bulk roll. Just know the people that buy these things are not going to know how to get that done. The people that ask me don't have a clue the chain gets dull.
Heck I don't even bother just have a stock of Stihl chains that you get anywhere. Sharpen them till I can't make them work, then put on a new one.
