I get the hot water from my barn into my basement with a Grundfos 26-96F circulator. Lately I've noticed that it will stop and start intermittently when the water is hot, which seems counterintuitive. I'm thinking I'm running my water too hot at 190, and that the pump must have a protection mechanism of some sort that shuts it off in extreme heat situations. That's just a guess.
Here's a few details: The pump is controlled by an aquastat at the boiler return that kicks it on when the return temp hits 160. I also have a Taco 007 that continuously circulates water from the supply into the return for thermal shock protection, instead of a mixing valve. The Grundfos is located in the basement and is on the return line.
I'm going to run the water temp down to 175 to see if that makes a difference, but if anyone has any ideas, I'd like to hear them.
