hey folks! i have a majestic prefab fp and chimney. i have ripped out the existing hearth and rebuilt one that will be up to code and stand the weight of my stove. i am going to use the existing chase to run double wall, insulated chimney pipe all the way up. there are two liners in the prefab chimney, (8" and 12") i will be removing the 8" obviously. now here is my problem, how am i going to support the weight of the new double wall pipe? i dont want to remove the 12" liner and i dont want to install a ss liner. the stove will not set inside the firebox AT ALL, it will be on the rebuilt hearth. should i block off at the top or bottom? i would prefer to block the bottom using sheet metal or insulation. i have tripple checked and i will have 6-8" clearence to combusibles all the way to the top of the chimney. the pipe i will be using is made by supervent, again the problem is supporting all the weight?!? maybe metal duct straps? any thoughts??? thanks, wes
