Sorry if this post question has been asked before. I just purchased an old farmhouse. The previous owners were che.., ah, thrifty. So I am not sure when the last time the chimney's were cleaned. All three chimney's are through the wall chimney's. Usually about a 3-4 foot run, then a 90 degree bend, then another 4 foot run through the wall, then another 90 degree bend. Outside it is about a 6-12 foot run depending on the chimney. So my question is what type of "rod" do I use that will flex 90 degrees? Or do I have to disassemble the pipes? If there is not a lot of creosote on the last section of the chimney can I assume that the entire chimney is clean? With this type of setup is it possible that the horizontal pipe has all the creosote or that is where it accumulates so there would be very little on the top? Having a chimney sweep come out is almost impossible due to the remote area.
Thanks for any comments
