I am installing a Selkirk chimney installation kit from Lowes. The Jotul F-100 Nordic is going to be near the outside wall on a 6/12 hip roof about four feet from the corner. There is little room between the ceiling joists and roof decking. Would it be OK to install the included insulation shield so that it protrudes the roof slightly under the flashing and if so is it acceptable for the side of the insulation shield to touch the roof joist?
In addition I am trying to confirm the hearth and wall protection. Is manufactured cement stone on 1/2" Durock on OSB acceptable hearth protection? The walls will also have the manufactured stone on 1/2" Durock attached to wood studs. The stove is spaced the minimum requirement of 10" from the stove corner to the studs. Will I need to be concerned with conductivity from the cement products to the wood studs and kraft backed insulation?
I've done general remodeling for myself and for hire as well as field service in technical and mechanical fields. I usually adapt to a new procedure quickly. I just need some help with the details, especially when the installation is not textbook.
Thanks in advance for your expert opinions.
