Running a Quad 3100 step-top, stove top was at 250 with smallish coals. I loaded it up for overnight with 2 chunks of boxelder and 3 chunks of oak I call over nighters (bigger full length slits) with a few smaller, gap filler splits, filling the box to just below the tubes and stepped the air down as usual. Maybe a little faster than normal. Walked away for 15 mins or so and came back to the Stove top at almost 800. With secondaries going crazy and the flames on the logs were not lazy they were actually rolling around pretty good as well! I Turned the blower on HIGH which kept it at 750. Still didnt like what i was seeing and took the side cover off and blocked the air inlet by the burn rate lever and also stuffed some ceramic blanket in the secondary tube's intake hole. Then it settled down drastically with very minimal air. I then removed the stuff and it burned fine. The wood was just really burnt up.
What did I do wrong to cause this to happen? Too much wood? Really dry wood? (Very low teens 10-11% mc 8 yr old oak and elm) Or do I have a possible over draft with 22 ft of chimney? This is the first time its gotten that far out of control and I don't want to see that happen again.
I tested the door seal and glass seal with a lighter flame as the fire continued burning and didnt notice any spots that sucked the flame in.
