Hi,
I did a prototype heat exchanger to extract heat from my dryer exhaust before it is vented outside the house. The idea was to see how well it might work and to investigate some of the issues like lint accumulation etc.
Well, it works pretty well considering its all made out of scrap materials. In its current state, it extracts energy equal to about 32% of the electrical energy required to run the dryer.
It dawned on me that if it could be taken a step further and made to condense much of the water out of the dryer airstream, then, with a good lint filter, it would likely be possible (for an electric dryer) to vent the dryer air inside the house. This is a double win in that you get the free heat from both the hot air and heat of vaporization of the water, and you also keep the dryer from pulling cold outside air into the house that needs to be heated by your furnace. You can check my numbers, but I get that a system like this could cut total clothes drying energy (electric and HVAC) by 80%.
This could be a thousand KWH a year saving for some families.
The big questions I have are: 1) why doesn't my current prototype condense out more moisture given that I'm lower the the dryer air to way below it dewpoint?, and 2) how can I change it so it does?
Any ideas or thoughts would be much appreciated.
Here are the details: http://www.builditsolar.com/Experimental/DryerHX/DryerHXTest1.htm
Sorry about the length.
I do realize that there are a whole raft of other ways to reduce clothes drying energy, but I would like to pursue this one and see how good it can be.
Gary
Gary
		![[Hearth.com] Clothes dryer heat recovery heat exchanger [Hearth.com] Clothes dryer heat recovery heat exchanger](/talk/proxy.php?image=http%3A%2F%2Fwww.begreensystems.co.uk%2FImages%2FHeat-Recovery-diagram.jpg&hash=f8ccdabd5c47e898bb2247fcbc820222)
