Cold Wood = Slow Start
woodmiser
390
Garnet Valley, PA
Cold start.... kindling fire well advanced....
Noticed this morning after bringing 30 deg wood into the house and loading into the stove. Practically snuffed out my kindling fires. If I bring it in to warm it it will suck heat out of the house.
What does everybody else do?
I keep a weeks worth or so in the stove room.
I haven't really noticed this problem. I bring wood into the stove from the attached, unheated garage area. Not sure what temp the wood is at (not quite as cold as outside wood), but lights right off when it lays on coals. Cheers!
After a small start-up fire at full throttle to warm up the chimney and fire-box, I stepped out to the 20* back deck and retrieve 3 oak splits, opened fire-box and inserted. They are thawing quite well.
Burn Safe:
Frank
My guess for the OP is that if you are bringing it in from outside directly to your stove, there is some moisture frozen into the wood.
When I was burning the furnace in the basement, I had room for about a cord, stacked in a corner. When one wall was empty I would burn from the other and fill the first wall back up. Wood was always dry and 60°+. It definitely took right off.
Still trying to figure out what to do with the stove. I've been keeping wood in the garage, and bringing the next load in after I load the stove. That load sits on the hearth for 12 hours or more. I don't know if it's the cold wood, or moisture, that makes it take off slower. We've had a ton of rain this fall, and EVERYTHING just feels a little damp.
I just think it's just the cold splits that are subduing the fire. I just need to stage a little more in my big black tub. Once the stove is blazing again it will pretty much burn anything you throw in there right away.
I keep two rows of wood in my basement, each with about a weeks worth of wood in them. One pile is the active pile, the second is placed for drying any external moisture from the wood before using it. Seems to be working well.
+1, that sounds like a sign of semi-seasoned wood. I've brought in wood at 15F and not noticed this.
I got a moisture meter and have been checking. The oak is less than 20%.
Can't say that I've noticed the temperature of the wood being a factor. Oak can hold a lot of moisture internally. It takes at least 2 years to dry after being split. Try resplitting one of these sluggish splits and check the freshly split face of the wood.
I'll check a few more. There could be some less than optimal splits but so far I have not found any. I do a fresh split when I check. I don't think most here are arguing that the cold splits do not effect the fire. It's basic physics.
When I say snuffs out, I mean my kindling fire on top of a small bed of coals. Now that it's getting consistently colder, I am using less kindling and am able to lite off the coals.
If it's DRY, it'll burn. (See How to Start a Fire 101)
Cold, small stuff starts to burn before large stuff.
Even cold large splits have finer edges, which catch and warm the rest,
then burn.
So, if you want to burn cold large splits without finer edges (especially 'rounds'),
try splitting them further to make a few smaller pieces to mix with the load.
Don't worry. Be happy.
Aye,
Marty
Granpa used to say, "Don't work harder, work smarter."
Maybe it was Grandma...
Just to look at some math (fuzzy logic, in my case). You are running big stoves. Lets say a 50 pound fuel load (just for conversations sake). 50 pounds of fuel at 60 degrees vs 50 pounds of fuel at 0 degrees is not alot of energy when compared to several hundred pounds of steel at a few hundred degrees with any kind of active coaling. This being said, I would think that on reload you would darn near have to be a machine to measure the difference. I "could" believe that it would be noticeable on a cold startup simply because you don't have any residual heat helping things out, but I think that would probably even be minimal. Just my opinion (and observance).
I'm not worried. Just was asking how others dealt with it. Yes it was more with the cold startup as I said in a previous post, once it's hot there are no delays.
I'll edit the topic to be more specific.
Think about it this way: Wood has to get up to 600 degrees or so to ignite. The difference between your inside warm wood and the outside stuff is only 40-50 degrees or so depending on how cold it is. It has to warm up 500+ degrees either way to burn. I don't think it would make much difference being pre-warmed.
Plus, I like the bugs to get warm and wake up in the stove and not my living room. ;)
I don't deal with it as I've not seen an issue with it. I took some in at 12F or so last night, and it lit off like a rocket.
Wood fresh off the pile can have water in/under the bark or in the outer part of the split. Here's a time when measuring the inside of the split tells you less. It's the OUTSIDE of the wood that catches fire. If the outside is a bit wetter, it will take a few to dry it out. Bringing it into a warm house for a couple days may be all that's needed to dry out the outside.
I think it's water (though a superficial amount overall), not temperature.
I was thinking about this yesterday............I keep my wood in the shed and bring it in by the armload, 2 or 3 a day. Anyway as I use big, straight splits that fit perfectly NS in the stove and with this particular load I place a triangular big split with flat side down and the other tight to the stone sidewall. Then I filled the rest with tightly packed very cold wood. Oh, this load was going on a good bed of overnight coals. Anyway, the fire took right off but my worry had more to do with the thermal shock of that cold side of wood being placed tight against a somewhat hot stone wall inside the stove......the sidewall is the just thick stone and is the same stone as the finished outside..
Anyway, it makes some sense to think if all that secondary combustion requires hot gasses to circulate around the burn tube, a big load of stone cold wood annt gonna help that process.
Probably just worring!
The difference IMO is too small to even notice. Wood does not need to warm up... it takes one second in the fire to do that.
Plus one to the above.
I had oak last year that when resplit showed ice crystals inside. These obviously didnt burn worth a hoot. Maybe its something like that, just not as extreme. Cold the water has to go through all stages, ice, water, then steam, versus just water to steam. But again id figure this would be hardly noticable.
Maybe more so, with such a large volume of wood. Id try the resplit and check, just to triple check.
Im with Jags...
Personally, I like to have 1-2 day's worth of wood near the hearth. Warming it up may be insignificant, but it can't hurt, and any surface moisture on the wood will help to humidify the room. Mostly, I want to go out into the cold to bring in wood when I feel like it, not necessarily when the stove needs feeding. For me, having splits handy by the stove takes some of the chore out of reloading. I like to do wood fetching as a separate chore. . .er. . .fun part of this hobby. :-)
++1
The ignition temperature of wood is probably the same ballpark as the famous paper flash point (451 F) right? The extra 30 degrees represents only 6% more temperature gain to ignite.
What could make a difference is that if the splits are frozen, there is a LOT of heat required to melt the 32F ice into 32F water.And of course the greener they are the more water to melt....
