I have a new Vogelzang Durango wood stove (it's a box stove style, 26" depth by 11" width/height firebox). I put it in my home where my previous EPA stove sat, and an older catalyst stove before that. Both of those burned fine.
This stove puffs smoke out of the front when lighting it cold, and after it's hot too, if the door is opened. If the fire is tall some flame will also leap out the front a few inches. Not all of the time, and maybe not all of the smoke chooses to wrongfully exit out the door, but at least 50% time/quantity. Once I close the door it burns fine. The exit port for the firebox is in the top front of the stove, where the door opens. I have checked all the joints and even added foil tape to them to see if there was a leak by chance. Did not make a difference. I've looked for obstructions and there aren't any.
I have 6" Duravent double wall pipe from stove flue collar to ceiling (almost 6 feet), and then it expands to an 8" stack (13 feet) to the cap above the roof. Stack top is 3 feet above highest portion of roof, which is about 17 feet away. I called manufacturer and sent pictures of system. Adjusted some interior insulation and fiber boards above the reburn pipes. Manufacturer says system seems very good, possibly too good. It thinks I possibly have too much draft due to too much chimney. Really? Too much draft is causing it to billow smoke from the open door? Wouldn't too much draft cause it to burn more aggressively?
Again, my two previous stoves had no problems. It lights and burns fine. I have two temp gauges, top of stove reaches 850 deg F, and 18" above collar on pipe reaches 250 deg F within 20 - 25 minutes of loading it half full (3-4 splits). I've tried cracking doors and windows, opening them wide too, and fans. I've also tried opening the stove door slowly, fast, a little and wide. The wind isn't blowing and it's presently mild weather...about 45-50 degrees F. My elevation is 6,000 feet, western central CO. Nothing changes the misbehavior. Please help. Manufacturers phone agent (didn't sound very sure of herself) suggested if draft was too strong it can cause symptoms similar to poor draft. Is that true? What else can I try? Thank you very much! Winter is almost here! andy
![[Hearth.com] Constant smoke when door is open [Hearth.com] Constant smoke when door is open](https://www.hearth.com/talk/data/attachments/164/164833-42c5420a9e747a3f1a1db30cc843db93.jpg?hash=tqCBLVDbVu)
![[Hearth.com] Constant smoke when door is open [Hearth.com] Constant smoke when door is open](https://www.hearth.com/talk/data/attachments/164/164834-c6d57dfb1a8c4b139d5efed7f58817af.jpg?hash=ey13QVmIo8)
![[Hearth.com] Constant smoke when door is open [Hearth.com] Constant smoke when door is open](https://www.hearth.com/talk/data/attachments/164/164859-8de944073663c4c16faae353b6c65b81.jpg?hash=UBA5ypmpjI)
