Conversion Kit for Wonderfire/Vermont Cast Stove
Rhonda2019
5
Michigan
Need a conversion kit for my Wonderfire/Vermont Castings Stove Model 2470, Serial # 1517.
This is to convert from propane to natural gas.
Bought stove and appears in excellent condition.
Conversion Kit is obselete. I have contacted 3 parts websites.
I have manual. Suggestions???
Thanks, Keith O. I discussed with Stove Parts Unlimited. As the model of stove is so old the conversion kit is obsolete and not available. Therefore, I need to pursue used parts or trading parts or some other option.
Here is more detail on conversion part needed.
NG 30. Part #: 000-5062. (See manual pages attached)
Do you have a local dealer who may be willing to install a new gas control for you ? Are you able to identify make and model of your gas valve ? I was able to identify my gas valve and the NG regulator kit was still available for it as a seperate part. That just leaves changing the pilot and main jet which is not complicated stuff for a stove technician.
The spec of your stove is almost identical to mine, but I cant tell if yours has B vent or direct vent
My gas valve looks like this. So far haven’t found a contractor who wants to take this on.
Rhonda, the ebay listing is for a Robertshaw 710-503 gas valve, set up for natural gas, with the same thermopile and thermocouple inputs as your current valve.
https://m.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=264125241479&_sacat=0
In addition, a tech would have to remove the main and pilot jets and determine replacement with larger diameters to suit the change from propane to NG.
I have been "winging it" with my stove, but I do have the benefit of being an engineer and having access to equipment some people may not have. I can refer you to my thread in this same forum "Generic LP to NG stove conversion"
Robert Shaw makes a low profile gas control i did away with the thermopile entirely just use a thermocouple... The unit comes with its own thermostat . Very simple to put on...
