Converting craft insert to wood stove
lep2014
2
sc
  • Want to start off by saying there is a lot of good info on site. Come on from time to time to get info and its always helpful. So, figured I would join and try to get some info on this project. I have a craft insert I would like to make into a working stove for my shop. Little info on shop stick built 20x30 12ft ceilings, drywall inside, and vinyl on outside. Reason for giving info on shop just want to give visual and for questions I have. How far from walls should stove sit? Should I run exhaust out of ceiling or out of wall? If out of wall what kind of protection should I have for vinyl. Size and what kind of stove pipe assuming double walled. Sorry, for all the questions but I want to make sure this is done right. Will get a picture of stove tomorrow, and be happy to answer any questions you have for me. Thanks in advance.
Done right would be using the product as designed and tested. The insert most likely was never meant to be used freestanding. For safety sake it has to be installed as unlisted with 36" clearances in all directions. Going straight up with the chimney is best and usually less expensive.
Yep, installing an insert as a freestander is essentially the same as installing an unlisted stove. If your local code has adopted NFPA 211 guidelines (most places do) that means 3 ft each direction. However, you can inquire if the minimum clearances can be reduced with heat shields: https://www.hearth.com/talk/wiki/nfpa-wall-clearance-reductions/
Your local code inspector is the relevant authority. Ask also your home insurance as some do not allow the installation of an unlisted stove at all.
Is that solely a shop or also used as a garage?
Thanks, for the info it is solely used as a shop. The insert was given to me so I figured if the setup would work it would be worth it considering that I cut and sell firewood also.
