Hello!
We currently have a gas fireplace, and I would like to convert it to a traditional wood-burning fireplace. We have an abundance of wood, and I prefer that over gas. I have watched several YouTube videos, and it appears like a wood stove insert with a new liner would be a great solution and one I think I can do myself.
The way this is set up is unique. The face of the fireplace is in a wall that behind we have access to -serving as our storage room.
Let me try my best to explain what is in this image.
A - Backend of the fireplace, huge amount of brick
B - 90 Degree elbow for exhaust
C - Connection point into the chimney
D - The actual chimney stack runs to the top of the house, located dead center in the middle of the house
E - Gas line
What is throwing me off is the distance of offset the fireplace has to the stack. This is very untraditional, and not seen anything else like it online. I am worried that a liner won't be able to make the necessary 90-degree bends (there are two).
I saw that you could buy 90-degree elbows online. I would plan to run the liner down to the first bend, place a 90-degree elbow, then run it a few feet to the actual fireplace, another elbow, and then down to the insert.
All new to me. Does that sound like a solid plan?
Also unsure what to do with the copper natural gas line; I will probably remove that to be safe. Might need to hire a professional to do that?
Thanks!
E - Gas line
Thanks!
