Hi.  Sorry for long post!  I am a new homeowner and am a little bit naive about the whole permitting process.  I am already halfway done with this project when I realized that hey maybe this should have been permitted.  I went with the certified fireplace installer that the fireplace store recommended so I just assumed everything would be OK.  Here is the situation:
I have an existing see-through gas masonry fireplace and I am trying to convert to a single-sided fireplace. I will close off the other side and have an entertainment center built on the closed off side. To achieve this I decided to install a gas insert on one side and then close it off with brick on the other and will frame drywall right up against the brick. The fireplace installer said ok no problem I can do it up to code. He didn't try to get permits or anything. I just assumed he would have told me if he needed to but in hindsight I probably should have pushed for it.
So what he ended up doing was laying two layers of brick inside the firebox (8"). He insists this is enough and up to code. The gas insert hasn't been installed yet but when it is installed there will be roughly 10"-12" of air space between the back of the gas insert and the back of the firebox wall. There is then the other 8" to the framing. I've tried to look up code and can't find anything specific regarding gas insert clearance. I saw code that said the back wall of the firebox needs to be at least 8" and if there is any combustible material up against it, it should be 12" of brick but this is for a wood-burning fireplace right? Does that code still have to be upheld for a gas insert inside a masonry fireplace? I do have room for another layer of brick, but is it necessary? I already started so I guess I can't get permits but I just want it to pass if they were to ever come back to inspect it.
Thanks.
Thanks.
