How Hot does the inside of an outside chimney need to get in order to start a creosote chimney fire? Any ideas of what the true or near temperature is? Thanks all...
![[Hearth.com] Creosote fire!.... [Hearth.com] Creosote fire!....](https://www.hearth.com/talk/data/attachments/119/119386-67dbed983626263b257e199397161c34.jpg?hash=QyNywHS1qY)
If the stove was smoldered for weeks/months, one hot burst from someone throwing some cardboard in the stove might set things off before the outside ever registered any high number.
Keep things under about 475 measured 12 to 18 inches above the stove on single wall pipe, as a general rule.
pen
Huh? Is this a general rule for all stoves? I have double wall pipe with probe at 18" and have had it up to 550F already. Others with the same stove say 600F is ok as well. Is your 475F cuttoff for those that have creosote buildup?
Boy we need a nomenclature for these flue temps, external, internal, double wall, single wall all gets a little confusing after a while.
Flame impingement is the most common cause of chimney fires. Pipe gets a coating of creosote in the connector pipe or chimney smoke chamber and flame gets to it and it is off to the races.
I did this with my old insert in the back yard a few years ago to show you what happens in the pipe when you toss those pizza boxes in the wood stove.
There are small "chimney fires" every time you burn, you just don't realize it. The problem arises when a stove has been allowed to burn on very low heat/smoldering which allows creosote to accumulate for an extended period of time. Then a hot fire happens and it all goes up in flames. The key is to burn you stove HOT once a day, this will help keep your creosote burnt off and not as easily accumulate. There is no substitute for regular cleaning.
. The answer is don't use wet wood and don't ever smolder in the first place.
Unless of course you hae a CAT stove, which has no issues with smoldering wood. And for the record, the PH does pretty good with wet wood, not that we should burn it, but......
! Just a bit of mis-information here. Like BrotherBart, this burning hot once a day is old stuff that just does not cut the mustard. Burn good fuel and you won't have creosote. This is why we can go years before cleaning our chimney; it simply stays clean but we don't do the hot fire bit and never have.We use essential cookies to make this site work, and optional cookies to enhance your experience.
