So recently, I got another Condar thermometer to replace/supplement the crappy Made-In-China Rutland one. I put the 2 Condars in the front corners, and the Rutland way on the back, within 3" of where the oslo stops, and the stainless pipe begins. I loaded it, and turned it down to below 1/2. A while later, the stove was running at around 550+, both sides, and the one in the back was reading around 700. Not sure if this is normal, as I never put a thermometer there. But that seems high. Granted, the stove was cooking…..What SHOULD the temp there be, given 550 at the front?
BTW, I know the Rutland one is in the ballpark, because I swapped it with the Condar, about the same. The Rutland's problem is mostly the needle sticking….
