Hi all
I’m interested in a direct vent gas fireplace and need some advice on options regarding an insert vs non insert. A little background.
I’m remodeling a room that has a traditional brick fireplace and hearth. The room has an existing wood burning fireplace with chimney going up about 30 feet. We are going for a cleaner modern look so we removed ugly painted recycled brick wall (veneer not structural) and hearth which will be replaced with a stacked stone. The firebox itself was in poor shape, so I took out the fire bricks on the sides and in back. I even removed the damper, leaving me with a 40” wide by 39” high by 20” deep rectangular brick box with a 12” flu going to the top of the house. On each side of the firebox is probably 20 in of brick that taper up towards the flu. I left the fire bricks in the bottom.
I’ve been looking at inserts - Regency / Mendota to start with. Since most units are smaller than my opening I thought I would use cement block to frame in the difference in the height so I can create a seamless look between the stone and fireplace. My questions are
1. Do I need to reinstall the fire bricks to use an insert? One local shop said I have to. Given I have a brick box with 20 inches of brick on each side, new fire bricks don’t quite add up unless these units get very hot. Above the fireplace there is brick / block too so nothing combustible is anywhere near the fireplace.
2. Is a regular non insert direct vent an option too? In reading the install instructions, these are usually framed in wood with perhaps steel studs in locations touching the unit. Do they run cooler than an insert? Also the units I’ve looked at have a pipe in pipe system which I think would still work given I’ve removed the damper.
3. Any brand recommendations also welcome. I’m not looking to heat the room so output is not my first concern.
Thanks!
Dave
Thanks!
Dave
