I just replaced my glass yesterday after a breakage (so I'm starting with a clean slate as I've had the problem I'm going to describe below before the glass broke) and am finally ready to admit there is something not quite right about my stove.
When I was at the dealer yesterday picking up some gasket cement, I was watching one of their Morso stoves burn and was amazed at how clean the glass was and was told they only clean the glass once a week. I have seen many similar comments here and then if their glass does get dirty, they just let the fire heat up and everything burns off. I know that most things need to be taken with a grain of salt but my stove glass needs to be cleaned every day and just as an experiment, I've really been watching it and for the first two hours after I fired it back up the glass stayed spotless but then quickly started developing a slight whitish haze (except for the top 1-2"). I didn't clean it this morning and although you can still see through the glass the haze is getting pretty thick. Since the Morso only allows 450 degrees on the flue 8" above the stove it is pretty hard to get it cranked up too much to see if things will burn off. I did just have a really nice secondary burn going with the flame hitting the glass really well and nothing seemed to change.
As far as I can tell, the draft is good. The only time I get any smoke in the house if I get my hand in the wrong spot and interrupt the airflow and get a quick puff out. The glass never gets black (unless a log falls against the glass and that will burn off as soon as the log is gone). As you can see from my avatar, I have a 90 above the stove and then about 15 degrees as the pipe enters the chimney (interior) and then the T going up from the basement about 35 feet to the top of the pipe. So I do have a slight violation of the 2 90 degree bend rule.
I would love to get up on the roof to check out the pipe (as the problem does seem to be a little worse as the winter as gone on) but with the snow don't feel like risking the 30 foot trip to the ground.
What I find curious is that 1" at the top of the glass that is staying pretty clean. It makes me wonder if somehow the airwash is blocked and that is what is keeping the glass from staying clean. I'm burning elm that is around 17% (but oddly the elm seems to do this more than the maple i was burning that was over 25%)
I hope that is enough information (and possibly WAY too much).
Thanks!!
Thanks!!
