The BlazeKing is cruising on "2" and I measured the flue temperature right above the stove collar at 289 and 115 at the ceiling collar (6' higher). Seems like a lot of temperature drop in that single wall pipe. Could this be my problem?
This is why Blaze King recommends double-wall pipe. You are getting the efficiency from the stove. The stove pipe should not be used to scavenge the last iota of heat with these stoves.
I would still like it if you could post a close up (clear) picture of that roof penetration area and the "rust".
I did have some slightly discolored icicles hanging from the cap this morning (we had freezing rain and snow last night) so I ran the stove on high to take the stove pipe temps up. Seems to have cleared the ice.What picture are you looking at that you can clearly see that???The discoloration is creosote, not rust. Note that is extends even onto the panel section where there is no cut. /
As begreen said, it is likely creosote dripping of your chimney pipe.
This can happen if you are burning wet wood, burning your fires too cool, or if it is cold and windy outside and the wind cools your chimney cap enough that the smoke condenses on it and drips off.
It is certainly not an ideal thing. If it continues it will stain your roof much worse and the creosote is corrosive and could eventually eat the finish off your metal roofing.
Make sure your wood is as dry as possible, and try to burn as cleanly as possible.
6" (inside diameter) + 4" (of wall material thickness (2" each side sides) = 8" So you should be fine with that Dektite if it good for pipes up to 13".
Damn!, I knew I should have used my calculator.eh.....6 + 4 = 10.
Oh well, I never was very good at math.
Actually, one of the nice things about painted metal roofs is you can wash it off easily. Providing you get to it before it corrodes the paint too much.I don't think there will be a simple solution to the stained roof.
It might just be condensation which is dripping off the cap to the roof. Nothing you can really do about that.
White roof while good for reflecting sun & heat, is not the best choice of color.
White anything on a house, never stays white.
The flashing is your main issue, or lack thereof actually.
