My VC Vigilant has a themostat lever on the back that controls the temp by opening and closiing a flap. Does those go bad? I know the stove is old so i just want to make sure it functions right and im not sure how to do that.
Just curious, first time with a stove and i know the one i have is old so i wanted to confirm whether they can go bad or not. Just trying to make sure all moving parts of operating properly. I was having issues keeping the temp up before but ive learned that you have to keep the secondary intake flap open during use so i think that helped alot
Changing out my old thermostat has turned into a nightmare. First, the new one is bent at an angle that doesn't allow for the rear heat shield like the original one. So I put the torch to the new one and bent the shaft to clear the shield. Now I can't thread it on the stove enough because it now won't clear the casting for the exhaust. How they got the original on is beyond me because it would have the same problem. I may have to cut the shaft, but then it will be too short to operate behind the shield. Some how some way I'll get this sucker to work.
Without seeing it I am not sure what the issue is. Just one thought,, why not remove the heat shield and modify it? Usually more than one way to skin a cat.
I bent the new one, screwed it in as far as I could. It's a loose fit, but seems to work. Not as good as the original but I'm two and a half months into the heating season and the house has been warm and comfortable. Not bad for a 42 year old stove.
I now know why the new thermostats have a bent handle. To clear the exhaust casting.
