My barometer is showing a 20% humidity level. Is that super low? I remember in Oct I had readings of 50-70%. I have a steamer on my stove so I figured that would generate more moisture. I would hate for my Windows to pop out. Thoughts?
Hey, what about all the old folks (like me ) that move to the SW US to breathe all that healthy air (which, when I visit my Sis in NM, is 5-10%?) Be that as it may, I don't like the dusty boogers I get down there. This house doesn't seem to dry out as much. A cheapie plastic thermometer/RH gauge I have is showing 40%, a better antique one that also has barometric pressure is showing 50+ but I don't know if it's calibrated right.20% is unhealthy,
I don't think so.I would hate for my Windows to pop out. Thoughts?
Relative humidity is the humidity relative to what the air can hold at its temperature. Air can hold more moisture as the temp increases.What is RH?
For those that have stand alone humidifiers, how do you prevent it from wetting up your floor and furniture?
This is actually a very confusing subject that I believe is often misunderstood. It's true that the indoor humidity levels generally drop during the winter; however, it isn't due to the temps of the stove itself, but is instead a result of the introduced combustion air. Since the humidity levels at low temperature are extremely low, compared to desirable levels at room temperature, any introduction of outside air will lower the RH.
RH levels are very dependent on temperature, but even if the temps near your stove are extremely high, the water vapor still isn't leaving your house, rather just migrating. Any combustion appliance, regardless of fuel source, will reduce the indoor humidity levels, unless it has a dedicated outdoor air connection.
I haven't had any issues with mine doing that. What kind of humidifier is it or do you know the model number?
Absolutely spot on.A house that is uncomfortably dry in winter almost always is one that leaks far too much air, flushing out human-produced moisture.
Mechanical ventilation is needed in a very tight house to keep humidity down, even in winter. The take-away lesson from this is that the proper thing to do for a house that is too dry in winter is a good air-sealing job to reduce leakage.
