Hello all, I stumbled across this site and hoping someone may be able to help. I have a Quadra-Fire 3100I purchased in 1999. The stove worked great for me until the heavy metal baffle plate above the air tubes rotted away (large hole in the center of the 1/4” steel plate). I was able to purchase and replace the baffle then and two more times since. My air tubes also split apart and I replaced them once so far (I’m afraid to inspect them again!). I’ve attached photos in case they can help others.
I’ve also replaced the glass in the door 3-4 times…each time was little harder to remove the flat head screws that hold the metal flange and glass in place. Last time I replaced the glass (2 years ago) a few of the screws snapped and two are striped…which is why I’m writing this.
First question is does anyone have any experience with this issue? If so, might you have a possible fix for the broken and stripped screws (I’ve tried penetrating oils and let it sit a couples days with no luck).
Second question is does anyone have a source for a new door assembly complete with new glass?
Sorry for lengthily message but I’ve had a lot of issues with the stove after five or six years and wanted to share what I’ve encountered in case this can help someone else.
Thank you all in advance!!
![[Hearth.com] Door assembly [Hearth.com] Door assembly](https://www.hearth.com/talk/data/attachments/322/322051-75c223cbfd318416a533eda0510b4f95.jpg?hash=v-ptwYIklQ)
