I just replaced the door gasket, after a failed dollar bill test. All was going great, until this morning, when the stove started getting too hot. I noticed a tiny gap at the top of the door.
Before putting on the new gasket, I tried adjusting the door latch, by taking out a washer and re-tightening the bolts. When tightened fully, the door wouldn't latch at all, when loosened a tiny bit, it would latch. However, now the actual latch, slightly spins. I think what's happening, is sometimes the position of the latch, is in the right spot, and the door shuts properly, but at other times if the latch moves (when loading more wood), it doesn't sit right, and the door won't seal properly.
To add: The door handle does wiggle a bit (when opened), about a quarter of an inch, should it be? If I tighten too much, the door won't close, if I don't tighten enough the latch spins. There's no in-between.
Ideas? High temp locktight on the latch?
