Hi there - so after 30 years with an old BK smoke dragon (with no cat) just a hole to the sky and a short 8 foot, 8inch flue, I finally installed a Drolet 1800 woodstove this fall. The BK was easy to start, and could handle giant logs but not efficient, Boy is this Drolet hard to start. We are located at 6,000 feet in Montana - the flue is a straight 12' long (recommended min length by Drolet) 6 feet inside, the rest outside. I didn't want to go much higher because of the winds. I did order a moisture meter that I'm waiting on - our wood usually seasons for one year here in this arid climate. It takes some persistence for about an hour to build some decent coals and some of the fam. just don't have the patience. It seems it could be a draft problem and I've wondered where the air intake holes are in case they are blocked.
Any tips on my transition to running this newer stove would be much appreciated. I also want to know how close to the secondary burn tubes can I fill with wood.
thankfully we are having a mild fall. I have already braced the chimney on the roof but I really want to hold back on more chimney height - from what I can see no -one else in the neighborhood has a significantly taller chimney and their fires are drawing, unless this stove is particularly finicky which is annoying and unsuspected - I picked it because it seemed like a good working class stove that could handle Canadian winters with minimum fuss - I do wonder if I should have gone with the next size up with a bigger firebox but the house is only 1600 sq ft and decided it would have driven us out of the house. I have a feeling I am going to have to muster the courage to burn it hotter than I am used to once I get the knack of lighting it to get the efficiency - even after thirty years of relying on wood for heat I'm a very cautious operator. I've watched some YouTubes and people really crank it up before closing it down for the night - more than I am used to
