I bought this stove used last year..and I'm very glad I had it over the winter! However, it would always high temperature alarm (H1) whenever I ran it on setting 3 or above. It has settings 1-6.
I read every thread on this board already about simliar issues with this stove...i'm a bit fed up. I'm simply not going to replace the computer only to find out it is another issue, like pump, vacuum sensor, blower..blah blah...Even if I fix this issue, I feel another issue will pop up.
Has anyone gutted the 'smart' electronics and run a pellet stove semi-manually? There are only a few functions..
1) Igniter - simple on/off switch
2) Exhaust blower - simple on/off switch
3) Heat exchanger blower - two speeds
4) Auger - variable resistor (potentiometer)
5) System power off - on/off switch
I have done some electrical work and I don't think it would be crazy to attempt this. Obviously, i would have to watch and make sure something crazy isn't going on with the stove because it will not autoshutoff for any reason...but a short will cut the home fuse. Still more protection than a wood stove.
Anyone done this?
Thanks!
Anyone done this?
Thanks!
