I have a DROLET Escape 1500. I am not getting the heat I feel I should out of it. I have yet to have the stove top temp above 600 degrees. I have had 550 ish on reloads with some heat already in the top. My stove top thermometer is right in the middle of the stove an inch or so in front of the top sheild/air vent. My house furnace thermostat is 20 feet away from the stove and I can get that thermometer to increase about 1 degree every 1 1/2 hours. If I start at 61 degrees in the morning I might get to 67 - 68 by late afternoon.
My current total flue height is 15 feet (Stove top to top of cap). Double wall stove pipe inside. I think my draft is good. I do not have any trouble starting a cold stove. Use Begreen's top down method.
Wood: Walnut (9.5 - 11.5 %) and Ash (11- 13%) (Walnut feels like balsa wood). On a cold start, I run N-S with about 25 -28 pieces in the firebox. They are 1 x 3; 2 x 2; 1 x 1 inches in size. About 9 -10 inches long. They were cut this way for my previous 1.2 cubic foot stove. (New wood for years down the road is cut at 4 x 4 type size.)
My flue thermometer is a K style probe; 2 inches long attached to a PID. I have it installed 9 1/2 inches above the stove top. I chose to put it there instead of at 20 inches as I decided not to drill through the overlapping sections of double stove pipe. I believe this gives me hotter stove pipe temperatures than if it was placed at 20 inches. And I have seen hot temperatures here but none that exceed the stove pipe specifications.
I do not get the 'flames shooting out of the secondary tube holes' burn that I experienced on my older stove. I get some that comes from the holes but not the intense 'flame-thrower' type. I have secondary burns across the top of the wood and also the blue flame that dances in the air. But not the flame thrower. Is this what causes the stove top to get hot?
The air control seems to work really well. Small adjustments make noticeable effects on the primary flames. But I don't really see an increase in secondary as I turn down the primary air. And I don't get the flame thrower. I am sure I have made mistakes and turned it down too quickly at times. And other times I have let it run hotter.
I have a outside air kit installed. It is 5 inch diameter as specified by DROLET. The length is about 8 feet from stove to outside. All horizontal. I can feel the air being sucked into it.
When I changed out stoves, I took two feet of outside chimney pipe off. I can add that back on if that will help. (pending the snow coming off my roof.)
But I am curious what other users of this stove have for flue length. And are you getting the heat you expect from this stove? Do you get the intense secondary burns?
